ASUS U30SD-XA1 RAM Replacement
  1. ASUS U30SD-XA1 RAM Replacement, RAM: step 1, image 1 of 1
    • Before removing the RAM, shut down your laptop and unplug the power adapter.
    • Turn the laptop over onto a flat surface.
  2. ASUS U30SD-XA1 RAM Replacement: step 2, image 1 of 1
    • At the top center on the back of the device, you will see a small square panel.
    • Use a Phillips screwdriver to remove two screws located on the panel.
  3. ASUS U30SD-XA1 RAM Replacement: step 3, image 1 of 2 ASUS U30SD-XA1 RAM Replacement: step 3, image 2 of 2
    • Ground yourself from electrostatic discharge by touching any metal objects or use your anti-static gloves.
    • System memories are very sensitive to static electricity.
    • Push apart the latches on either side of the slot that hold the RAM in place, but gently.
    • Use firm pressure as needed. You will hear the RAM pop out of the slot.
    • Take the RAM stick out carefully, and set it aside on an anti-static surface.
  4. ASUS U30SD-XA1 RAM Replacement: step 4, image 1 of 1
    • To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
    • Make sure your hands are clean and do not let your fingerprints get on the memory.
    • Line up the top corners of the new RAM with the top edges of the now empty panel.
    • Slide the RAM into the slot until it's firmly in place.
    • Once you hear the RAM stick click into place, you'll know you did it correctly.
    • Now just screw the panel door back on and you're finished!
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
2 other people completed this guide.
Julie M Paul
164 Reputation
1 Guide authored
Texas Tech, Team 3-1, Rauch SU 2015 Member of Texas Tech, Team 3-1, Rauch SU 2015
TTU-RAUCH-SU15S3G1
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,423
