Acer Aspire 5100 RAM Replacement
  1. Acer Aspire 5100 RAM Replacement, RAM: step 1, image 1 of 2 Acer Aspire 5100 RAM Replacement, RAM: step 1, image 2 of 2
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: step 2, image 1 of 3 Acer Aspire 5100 RAM Replacement: step 2, image 2 of 3 Acer Aspire 5100 RAM Replacement: step 2, image 3 of 3
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
7 other people completed this guide.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
10 Guides authored
One Comment
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 20
All Time: 16,314
