Acer Aspire 5741-5698 WIFI Chipset Replacement
  1. Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: step 1, image 1 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: step 1, image 2 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: step 1, image 3 of 3
    • Begin on the back side of your laptop, locate these two screws then remove them with the JIS #0 driver bit.
  2. Acer Aspire 5741-5698 WIFI Chipset Replacement: step 2, image 1 of 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 2, image 2 of 2
    • Once screws are removed you can pry up the panel to reveal some of your computers components.
  3. Acer Aspire 5741-5698 WIFI Chipset Replacement: step 3, image 1 of 1
    • Locate your computers WIFI chip; it will have black and white wires attached to it.
  4. Acer Aspire 5741-5698 WIFI Chipset Replacement: step 4, image 1 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 4, image 2 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 4, image 3 of 3
    • Using your fingers or a spudger, remove the black and white cables from the chip, at the connector.
  5. Acer Aspire 5741-5698 WIFI Chipset Replacement: step 5, image 1 of 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 5, image 2 of 2
    • Using the same JIS#0 screw driver remove the single small 1/4 inch long screw.
  6. Acer Aspire 5741-5698 WIFI Chipset Replacement: step 6, image 1 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 6, image 2 of 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: step 6, image 3 of 3
    • Now that the chip is released just gently remove it from its connector seat.
Alex Imbery
133 Reputation
1 Guide authored
Cal Poly, Team S18-G6, White Winter 2019 Member of Cal Poly, Team S18-G6, White Winter 2019
CPSU-WHITE-W19S18G6
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 592
