Acer Aspire E1-470P-6659 Cooling Fan Replacement
  1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 2, image 1 of 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 3, image 1 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 3, image 2 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 3, image 3 of 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 4, image 1 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 4, image 2 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 4, image 3 of 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: step 5, image 1 of 2 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: step 5, image 2 of 2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 6, image 1 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 6, image 2 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 6, image 3 of 3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 7, image 1 of 2 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 7, image 2 of 2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 8, image 1 of 1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 9, image 1 of 1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 10, image 1 of 1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: step 11, image 1 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: step 11, image 2 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: step 11, image 3 of 3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 12, image 1 of 2 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 12, image 2 of 2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
  13. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: step 13, image 1 of 2 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: step 13, image 2 of 2
    • Flip the motherboard and fan piece over.
    • Remove the four screws using the Phillips #000 Screwdriver.
  14. Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 14, image 1 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 14, image 2 of 3 Acer Aspire E1-470P-6659 Cooling Fan Replacement: step 14, image 3 of 3
    • Flip the motherboard over and slowly remove the tape holding the cooling fan down.
    • Use a spudger to remove the top of the fan from the base of the fan.
    • Remove the cooling fan component from both the tape and the motherboard.
Faith Lobaton
497 Reputation
3 Guides authored
UC Davis, Team S4-G5, Lore Fall 2018 Member of UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 402
