Acer Aspire E1-572G Keyboard Replacement
  1. Acer Aspire E1-572G Keyboard Replacement, Keyboard: step 1, image 1 of 2 Acer Aspire E1-572G Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Press and slide battery-lock button to remove the battery.
  2. Acer Aspire E1-572G Keyboard Replacement: step 2, image 1 of 1
    • Remove 17x Philips screws
  3. Acer Aspire E1-572G Keyboard Replacement: step 3, image 1 of 1
    • Remove the plastic cover
    • Remove 2x Philips screws
  4. Acer Aspire E1-572G Keyboard Replacement: step 4, image 1 of 3 Acer Aspire E1-572G Keyboard Replacement: step 4, image 2 of 3 Acer Aspire E1-572G Keyboard Replacement: step 4, image 3 of 3
    • Start opening the top starting at the side of the screen
    • Use plastic tools to avoid damaging the cover.
  5. Acer Aspire E1-572G Keyboard Replacement: step 5, image 1 of 3 Acer Aspire E1-572G Keyboard Replacement: step 5, image 2 of 3 Acer Aspire E1-572G Keyboard Replacement: step 5, image 3 of 3
    • Disconnect 3x flex cables
  6. Acer Aspire E1-572G Keyboard Replacement: step 6, image 1 of 1
    • Remove 6x Philips screws
    • The 2 Philips screws at the top are different from the other 4 (thicker)
    • Remove 3x small (silver) Philips screws
  7. Acer Aspire E1-572G Keyboard Replacement: step 7, image 1 of 1
    • Remove the metal plate by sliding it up and then flipping it over
    • Be careful to not damage the flex cable attached to the metal plate.
  8. Acer Aspire E1-572G Keyboard Replacement: step 8, image 1 of 1
    • Disconnect 2x aluminium grounding
    • Lift the keyboard out
10 other people completed this guide.
Sander Degryse
293 Reputation
1 Guide authored
One Comment
Dear author,
I've done the replacement the exact same way, though I did it without your guide. Yet, my keyboard does not work properly after replacement i.e. WASD keys not working, UP DOWN LEFT RIGHT not working. What could be the problem? Kindly contact me via yukozashireiji@gmail.com
Yukozashi Reiji - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 35
All Time: 7,197
