Acer Aspire E5-573G Battery Replacement
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: step 1, image 1 of 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: step 2, image 1 of 1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: step 3, image 1 of 1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: step 4, image 1 of 1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: step 5, image 1 of 1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: step 6, image 1 of 1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: step 7, image 1 of 1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
14 other people completed this guide.
Alex Bahm
2,232 Reputation
6 Guides authored
Cal Poly, Team S12-G5, Banghart Winter 2018 Member of Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Members
15 Guides authored
One Comment
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Reply
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 53
All Time: 21,704
