Acer Aspire M5-583P-9688 Battery Replacement
  1. Acer Aspire M5-583P-9688 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Acer Aspire M5-583P-9688 Battery Replacement: step 2, image 1 of 2 Acer Aspire M5-583P-9688 Battery Replacement: step 2, image 2 of 2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Battery Replacement: step 3, image 1 of 2 Acer Aspire M5-583P-9688 Battery Replacement: step 3, image 2 of 2
    • Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
  4. Acer Aspire M5-583P-9688 Battery Replacement: step 4, image 1 of 2 Acer Aspire M5-583P-9688 Battery Replacement: step 4, image 2 of 2
    • Unplug the marked plug from the motherboard and this will complete the removal of the battery.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,533
