Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: step 1, image 1 of 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: step 1, image 2 of 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: step 3, image 1 of 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: step 3, image 2 of 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 4, image 1 of 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 5, image 1 of 1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: step 6, image 1 of 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: step 6, image 2 of 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 7, image 1 of 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 7, image 2 of 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: step 7, image 3 of 3
    Buy
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Jessica Beckford
527 Reputation
4 Guides authored
USF Tampa, Team S15-G4, Boczar Spring 2018 Member of USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 188
