Acer Chromebook 13 CB5-311-T7NN Battery Replacement
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: step 2, image 1 of 1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: step 3, image 1 of 1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: step 4, image 1 of 1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: step 5, image 1 of 2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: step 5, image 2 of 2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 35
All Time: 1,421
