Acer Chromebook C720 Battery Replacement
  1. Acer Chromebook C720 Battery Replacement, Battery: step 1, image 1 of 3 Acer Chromebook C720 Battery Replacement, Battery: step 1, image 2 of 3 Acer Chromebook C720 Battery Replacement, Battery: step 1, image 3 of 3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using a Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Battery Replacement: step 2, image 1 of 2 Acer Chromebook C720 Battery Replacement: step 2, image 2 of 2
    • Remove the two 3mm screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Battery Replacement: step 3, image 1 of 2 Acer Chromebook C720 Battery Replacement: step 3, image 2 of 2
    • Disconnect the 8-pin ribbon cable from the motherboard.
    • Remove the battery pack from the device.
4 other people completed this guide.
Benjamin Rahman
517 Reputation
3 Guides authored
IUPUI, Team S2-G5, Harley Spring 2019 Member of IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,038
