Acer Chromebook C720-2420 Battery Replacement
  1. Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: step 1, image 1 of 2 Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: step 1, image 2 of 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Battery Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Battery Replacement, Battery: step 3, image 1 of 2 Acer Chromebook C720-2420 Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Battery Replacement: step 4, image 1 of 2 Acer Chromebook C720-2420 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Battery Replacement: step 5, image 1 of 1
    • Remove the battery.
Jessica Beckford
527 Reputation
4 Guides authored
USF Tampa, Team S15-G4, Boczar Spring 2018 Member of USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 557
