Acer Chromebook C720-2844 Battery Replacement
  1. Acer Chromebook C720-2844 Battery Replacement, Battery: step 1, image 1 of 3 Acer Chromebook C720-2844 Battery Replacement, Battery: step 1, image 2 of 3 Acer Chromebook C720-2844 Battery Replacement, Battery: step 1, image 3 of 3
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Battery Replacement: step 2, image 1 of 1
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Battery Replacement: step 3, image 1 of 2 Acer Chromebook C720-2844 Battery Replacement: step 3, image 2 of 2
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
Fabian Sanchez
247 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 22
All Time: 206
