Acer Chromebook C720-2848 SSD Replacement
  1. Acer Chromebook C720-2848 SSD Replacement, Back Cover: step 1, image 1 of 2 Acer Chromebook C720-2848 SSD Replacement, Back Cover: step 1, image 2 of 2
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 SSD Replacement: step 2, image 1 of 3 Acer Chromebook C720-2848 SSD Replacement: step 2, image 2 of 3 Acer Chromebook C720-2848 SSD Replacement: step 2, image 3 of 3
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 SSD Replacement, SSD: step 3, image 1 of 2 Acer Chromebook C720-2848 SSD Replacement, SSD: step 3, image 2 of 2
    • Unscrew screw holding SSD card in place.
    • Slide out the SSD card towards you to remove it.
    • The SSD card is the blue chip on the right connected to the motherboard.
    • Be sure to store this screw apart from the others as it is a different length.
2 other people completed this guide.
Robert Escobio
597 Reputation
4 Guides authored
USF Tampa, Team S9-G3, Remmell Fall 2017 Member of USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 524
