Acer Chromebook CB3-431-C5EX Battery Replacement
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: step 1, image 1 of 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: step 2, image 1 of 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: step 3, image 1 of 2 Acer Chromebook CB3-431-C5EX Battery Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: step 5, image 1 of 2 Acer Chromebook CB3-431-C5EX Battery Replacement: step 5, image 2 of 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: step 6, image 1 of 1
    • Carefully lift the entire battery pack out of the laptop.
7 other people completed this guide.
Elsa Bassett
414 Reputation
1 Guide authored
Cal Poly, Team S17-G3, Banghart Spring 2017 Member of Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Members
10 Guides authored
2 Comments
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Reply
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 72
All Time: 8,616
