Acer Nitro 5 AN515-53-55G9 Fan Replacement
  1. Acer Nitro 5 AN515-53-55G9 Fan Replacement, Fan: step 1, image 1 of 2 Acer Nitro 5 AN515-53-55G9 Fan Replacement, Fan: step 1, image 2 of 2
    • Make sure the laptop is off and unplugged before beginning the fan replacement.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 2, image 1 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 2, image 2 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 2, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the 9 mm screw located in the bottom left corner of the RAM tray cover.
    • Using a plastic opening tool, remove the RAM tray cover.
  3. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 3, image 1 of 2 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 3, image 2 of 2
    • Remove the screw from the hard drive cover on the left side of the laptop with a Phillips #0 screwdriver.
    • Lift up the tray covering using a spudger.
  4. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 4, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the fourteen 9 mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 5, image 1 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 5, image 2 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 5, image 3 of 3
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 6, image 1 of 2 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 6, image 2 of 2
    • Lift the back cover off once all the clips have been disengaged.
    • The fan for the device is located at the top left of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 7, image 1 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 7, image 2 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 7, image 3 of 3
    • Using your fingers, slide out the two fan cables from their connectors on the motherboard.
  8. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 8, image 1 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 8, image 2 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 8, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws holding the fan assembly in place.
  9. Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 9, image 1 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 9, image 2 of 3 Acer Nitro 5 AN515-53-55G9 Fan Replacement: step 9, image 3 of 3
    • Gently remove the fans.
4 other people completed this guide.
6 Comments
Sometime after Step 3 but before Step 5, you HAVE TO unscrew and remove the hard drive. If you do not, you will inadvertently pull the drive’s cable out of its connector on the motherboard when you remove the back cover.
This happened to me, and I spent a good hour freaking out that I had trashed the computer.
After looking closely at the motherboard, I was finally able to find that connector. It is underneath the connector to the USB board, and it’s easy enough to reconnect it once you also disconnect the cable to the USB board.
But you will save yourself a WHOLE LOT of trouble if you carefully remove the hard drive first before you remove the back cover.
Jason Smith - Reply
I pulled the drive’s cable out of the motherboard connector. I think I plugged it back incorrectly but now I can’t find the drive on my computer. Do I have to somehow boot the drive up or is it just plugged in incorrectly?
Jerry Di -
I freaked out reading your comment because i couldn't find my hard drive. Then i realized that i have a ssd and it's not installed at that spot.
Jojo Hung -
When it said that to just pull out the fans it never told me that i had to remove the tape and now I’m scared to take the tape off is this needed?
Mr Derpy - Reply
Where would i get a new fan
Dawie Van der Berg - Reply
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 221
All Time: 17,589
