Acer Nitro 5 AN515-55-56GN HDD Replacement
  1. Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: step 1, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: step 1, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: step 1, image 3 of 3
    • Turn off the laptop and unplug it from the charging cord.
    • Flip the laptop over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove ten 9 mm screws.
  2. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 2, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 2, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 2, image 3 of 3
    • Use your fingers or an opening tool to remove the back case by separating it at the seam.
    • Work your way gently around the perimeter to undo the clips.
    • Remove the back case.
  3. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 3, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 3, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 3, image 3 of 3
    • Unplug the battery cable from the connector attaching the battery to the motherboard.
    • Make sure that the laptop battery is unplugged or remove the battery before installing the HDD.
  4. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 4, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 4, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 4, image 3 of 3
    • Use the Phillips #0 screwdriver to remove four 3 mm screws from the hard drive bracket.
    • Remove the bracket from the device.
  5. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 5, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 5, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 5, image 3 of 3
    • Place the HDD 1TB in the bracket.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws that hold the HDD in the bracket.
    • The 2 mm screws are included with the new HDD.
  6. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 6, image 1 of 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 6, image 2 of 2
    • Attach the SATA connector to the HDD.
  7. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 7, image 1 of 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 7, image 2 of 2
    • Slide the HDD into the socket on the motherboard.
    • Replace the four 3 mm screws using the Phillips #0 screwdriver.
  8. Acer Nitro 5 AN515-55-56GN HDD Replacement: step 8, image 1 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 8, image 2 of 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: step 8, image 3 of 3
    • Slide the hard drive cable into the connector on the motherboard.
    • Flip the black lock down to secure the cable.
That is all step-to-step on how to Install the new HDD to the laptop Acer Nitro 5 (AN515-55-56GN)
5 other people completed this guide.
Duy Nguyen
253 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 46
Past 30 Days: 191
All Time: 5,103
