Anker SoundCore 2 Battery Replacement
  1. Anker SoundCore 2 Battery Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Battery Replacement, Front Panel: step 1, image 2 of 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Battery Replacement, Battery: step 2, image 1 of 3 Anker SoundCore 2 Battery Replacement, Battery: step 2, image 2 of 3 Anker SoundCore 2 Battery Replacement, Battery: step 2, image 3 of 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Battery Replacement: step 3, image 1 of 3 Anker SoundCore 2 Battery Replacement: step 3, image 2 of 3 Anker SoundCore 2 Battery Replacement: step 3, image 3 of 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard to expose the battery.
  4. Anker SoundCore 2 Battery Replacement: step 4, image 1 of 2 Anker SoundCore 2 Battery Replacement: step 4, image 2 of 2
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
  5. Anker SoundCore 2 Battery Replacement: step 5, image 1 of 2 Anker SoundCore 2 Battery Replacement: step 5, image 2 of 2
    • Unplug the wire that connects the battery with the motherboard.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
2 other people completed this guide.
4 Comments
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - Reply
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - Reply
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - Reply
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis -
Past 24 Hours: 16
Past 7 Days: 101
Past 30 Days: 436
All Time: 9,377
