Anker SoundCore 2 Bluetooth Chip Replacement
  1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: step 1, image 2 of 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 1 of 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 2 of 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 3 of 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 1 of 3 Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 2 of 3 Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 3 of 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: step 4, image 1 of 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: step 4, image 2 of 2
    • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
    • For help desoldering and soldering, follow this guide.
0 Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 65
All Time: 1,739
