Anker SoundCore 2 Speaker Replacement
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Speaker Replacement, Front Panel: step 1, image 2 of 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: step 2, image 1 of 3 Anker SoundCore 2 Speaker Replacement, Speaker: step 2, image 2 of 3 Anker SoundCore 2 Speaker Replacement, Speaker: step 2, image 3 of 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: step 3, image 1 of 3 Anker SoundCore 2 Speaker Replacement: step 3, image 2 of 3 Anker SoundCore 2 Speaker Replacement: step 3, image 3 of 3
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
9 Comments
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Reply
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Reply
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - Reply
jafarez -
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 115
All Time: 4,267
