Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: step 1, image 1 of 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Alex Wineteer
154 Reputation
1 Guide authored
Cal Poly, Team 25-30, Garner Spring 2011 Member of Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 3,063
