Introduction
Use this guide to replace a broken, cracked, or defective screen on your Apple Watch Series 7.
It is possible to replace the screen of the Apple Watch Series 7 without removing or disconnecting the battery first. However, this can lead to a malfunction of the NFC antenna under certain circumstances. If you are unsure about your repair, we recommend that you first follow the battery guide and then continue with Step 23 of this guide.
Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed.
This guide shows the procedure on the cellular/LTE version of the watch, but the standard GPS-only version is similar.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before starting repairs, take your watch off the charger and power it down.
Tool used on this step:Safety Glasses$3.19
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
Once inserted, tilt the blade to pry the display open slightly and create a gap between the screen and the watch body.
Insert an opening pick in the gap your created.
Slide the opening pick along the short edge of the watch to slice the adhesive.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upward position.
Prepare an iOpener and apply it to the rear side of your Apple Watch for at least two minutes to loosen the adhesive underneath the battery.
Insert an opening pick between watch body and the long edge of the battery.
Use constant, steady pressure to slowly pry up the battery.
Carefully lift and swing the battery out of its recess and place it next to the watch body.
Use one arm of your tweezers or the pointed end of a spudger to pry up the lock bar on the ZIF connector securing the battery cable.
Use a pair of tweezers to pull the battery cable out of the battery ZIF connector.
Use a Tri-Point Y000 screwdriver to remove the 1.1 mm-long screw securing the battery connector bracket.
Use a pair of tweezers to remove the battery connector bracket.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a spudger or one arm of your tweezers to pry up the lock bar on the ZIF connectors securing the display cables.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the protective tape on its rear side.
Carefully slide an opening pick underneath the display cables to separate them from the screen.
Use a pair of tweezers to pull both display cables out of the ZIF connectors.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
3 other people completed this guide.
