Asus Chromebook C300M Mousepad Replacement
  1. Asus Chromebook C300M Mousepad Replacement, Mousepad: step 1, image 1 of 2 Asus Chromebook C300M Mousepad Replacement, Mousepad: step 1, image 2 of 2
    • Flip the Chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M Mousepad Replacement: step 2, image 1 of 1
    • Separate the plastic case from the keyboard at the seam by using a plastic opening tool.
  3. Asus Chromebook C300M Mousepad Replacement: step 3, image 1 of 3 Asus Chromebook C300M Mousepad Replacement: step 3, image 2 of 3 Asus Chromebook C300M Mousepad Replacement: step 3, image 3 of 3
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using spudger.
  4. Asus Chromebook C300M Mousepad Replacement: step 4, image 1 of 3 Asus Chromebook C300M Mousepad Replacement: step 4, image 2 of 3 Asus Chromebook C300M Mousepad Replacement: step 4, image 3 of 3
    • Remove the keyboard and flip it onto its front. You should see the back of the mousepad.
    • Lift the foil strips to reveal two hidden screws. Then remove all four 2mm screws from the top of the trackpad with the Phillips #1 screwdriver.
    • Remove the mousepad by sliding it upward.
Rachel Cadle
259 Reputation
2 Guides authored
IUPUI, Team S3-G2, Harley Spring 2019 Member of IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 11
All Time: 338
