Asus Chromebook C300MA-BBCLN12 Battery Replacement
  1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: step 1, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 3 of 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 4, image 1 of 1
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 5, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 5, image 2 of 2
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the bottom housing.
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 17
All Time: 387
