Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: step 1, image 1 of 2 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: step 1, image 2 of 2
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 2, image 1 of 1
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 3, image 1 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 3, image 2 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 3, image 3 of 3
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 4, image 1 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 4, image 2 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 4, image 3 of 3
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 5, image 1 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 5, image 2 of 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: step 5, image 3 of 3
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
7 other people completed this guide.
2 Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 95
All Time: 3,851
