AuKing M8-F Motherboard Replacement
  1. AuKing M8-F Motherboard Replacement, Motherboard: step 1, image 1 of 2 AuKing M8-F Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. AuKing M8-F Motherboard Replacement: step 2, image 1 of 3 AuKing M8-F Motherboard Replacement: step 2, image 2 of 3 AuKing M8-F Motherboard Replacement: step 2, image 3 of 3
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
  3. AuKing M8-F Motherboard Replacement: step 3, image 1 of 3 AuKing M8-F Motherboard Replacement: step 3, image 2 of 3 AuKing M8-F Motherboard Replacement: step 3, image 3 of 3
    • Flip up the black locking flaps then remove the two ribbon cables.
  4. AuKing M8-F Motherboard Replacement: step 4, image 1 of 2 AuKing M8-F Motherboard Replacement: step 4, image 2 of 2
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
  5. AuKing M8-F Motherboard Replacement: step 5, image 1 of 2 AuKing M8-F Motherboard Replacement: step 5, image 2 of 2
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
Jennifer Vazquez
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 117
