Barbie Doll Hair Replacement
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: step 1, image 1 of 3 Barbie Doll Hair Replacement, Barbie Doll Hair: step 1, image 2 of 3 Barbie Doll Hair Replacement, Barbie Doll Hair: step 1, image 3 of 3
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: step 2, image 1 of 2 Barbie Doll Hair Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: step 3, image 1 of 3 Barbie Doll Hair Replacement: step 3, image 2 of 3 Barbie Doll Hair Replacement: step 3, image 3 of 3
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: step 4, image 1 of 3 Barbie Doll Hair Replacement: step 4, image 2 of 3 Barbie Doll Hair Replacement: step 4, image 3 of 3
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: step 5, image 1 of 1
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: step 6, image 1 of 1
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: step 7, image 1 of 2 Barbie Doll Hair Replacement: step 7, image 2 of 2
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
Finish Line
Miranda Comstock
170 Reputation
1 Guide authored
UC Davis, Team 2-3, Andersen Winter 2023 Member of UC Davis, Team 2-3, Andersen Winter 2023
UCD-ANDERSEN-W23S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,672
