Beats Studio3 Wireless Battery Replacement
  1. Beats Studio3 Wireless Battery Replacement, Battery: step 1, image 1 of 2 Beats Studio3 Wireless Battery Replacement, Battery: step 1, image 2 of 2
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
  2. Beats Studio3 Wireless Battery Replacement: step 2, image 1 of 2 Beats Studio3 Wireless Battery Replacement: step 2, image 2 of 2
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
  3. Beats Studio3 Wireless Battery Replacement: step 3, image 1 of 3 Beats Studio3 Wireless Battery Replacement: step 3, image 2 of 3 Beats Studio3 Wireless Battery Replacement: step 3, image 3 of 3
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
  4. Beats Studio3 Wireless Battery Replacement: step 4, image 1 of 1
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Beats Studio3 Wireless Battery Replacement: step 5, image 1 of 2 Beats Studio3 Wireless Battery Replacement: step 5, image 2 of 2
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
4 other people completed this guide.
Lourdes Dejesus
213 Reputation
1 Guide authored
3 Comments
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Reply
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb -
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Reply
Past 24 Hours: 15
Past 7 Days: 67
Past 30 Days: 299
All Time: 3,539
