Beyerdynamic MMX100 Volume Controller Repair
  1. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 3 of 3
    • Twist the left speaker cushion towards you, and pull off the headset.
  2. Beyerdynamic MMX100 Volume Controller Repair: step 2, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 2, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 2, image 3 of 3
    • Using the 2.0mm Phillips-Head screwdriver, unscrew the two 0.6mm screws at the end of the left side headband.
  3. Beyerdynamic MMX100 Volume Controller Repair: step 3, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 3, image 2 of 2
    • Hold open the top part of the headband. Slide out the left earphone.
  4. Beyerdynamic MMX100 Volume Controller Repair: step 4, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 4, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 4, image 3 of 3
    • Using the 3.0mm Phillips-Head Screwdriver, unscrew the three 0.7 mm screws on the left speaker cover.
  5. Beyerdynamic MMX100 Volume Controller Repair: step 5, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 5, image 2 of 2
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.5mm screws on the volume control component.
  6. Beyerdynamic MMX100 Volume Controller Repair: step 6, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 6, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 6, image 3 of 3
    • Take out, and flip over, the volume control component.
  7. Beyerdynamic MMX100 Volume Controller Repair: step 7, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 7, image 2 of 2
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.3mm screws on the board. Then, take off the volume wheel.
  8. Beyerdynamic MMX100 Volume Controller Repair: step 8, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 8, image 2 of 2
    • Hazardous situation which, if not avoided, could result in minor or moderate injury.
    • Using a soldering iron, desolder the damaged wires and the prongs on either side of the board.
Anthony Grande
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 62
All Time: 252
