Canon AE-1 SLR Lens Mount Replacement
  1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: step 1, image 1 of 2 Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: step 1, image 2 of 2
    • Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
    • The first set of screws is located on the front and bottom of the lens casing.
  2. Canon AE-1 SLR Lens Mount Replacement: step 2, image 1 of 2 Canon AE-1 SLR Lens Mount Replacement: step 2, image 2 of 2
    • Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
  3. Canon AE-1 SLR Lens Mount Replacement: step 3, image 1 of 1
    • Remove the lens casing by pulling it away from the body of the camera.
  4. Canon AE-1 SLR Lens Mount Replacement: step 4, image 1 of 1
    • Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
  5. Canon AE-1 SLR Lens Mount Replacement: step 5, image 1 of 3 Canon AE-1 SLR Lens Mount Replacement: step 5, image 2 of 3 Canon AE-1 SLR Lens Mount Replacement: step 5, image 3 of 3
    • Pull the SLR lens mount away from the body of the camera.
    • Be aware that a pin will fall out when the SLR lens mount is removed.
6 other people completed this guide.
Joe Blumberg
213 Reputation
1 Guide authored
UW Stout, Team 5-1, Zhou Fall 2011 Member of UW Stout, Team 5-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G1
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 56
All Time: 11,734
