Compaq iPAQ Pocket PC 3830 Motherboard Replacement
  1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Remove the four 0.8mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 2, image 1 of 1
    • Remove the two screws on top of the motherboard and the two screws on bottom of motherboard
  3. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 3, image 1 of 2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 3, image 2 of 2
    • Detach the wires from their combs on the motherboard.
  4. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 4, image 1 of 1
    • Detach from comb that is located on motherboard.
  5. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 5, image 1 of 2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 5, image 2 of 2
    • Remove the small piece from the motherboard.
  6. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove last piece from the comb on the motherboard.
  7. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: step 7, image 1 of 1
    • Remove the motherboard by simply lifting it.
Sedina Cavcic
464 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 525
