Craig CMP801 Volume Controls Replacement
  1. Craig CMP801 Volume Controls Replacement, Back Cover: step 1, image 1 of 2 Craig CMP801 Volume Controls Replacement, Back Cover: step 1, image 2 of 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Volume Controls Replacement: step 2, image 1 of 2 Craig CMP801 Volume Controls Replacement: step 2, image 2 of 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Volume Controls Replacement: step 3, image 1 of 2 Craig CMP801 Volume Controls Replacement: step 3, image 2 of 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Volume Controls Replacement, Volume Controls: step 4, image 1 of 2 Craig CMP801 Volume Controls Replacement, Volume Controls: step 4, image 2 of 2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 Volume Controls Replacement: step 5, image 1 of 2 Craig CMP801 Volume Controls Replacement: step 5, image 2 of 2
    Tool used on this step:
    $3.99
    Buy
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 Volume Controls Replacement: step 6, image 1 of 2 Craig CMP801 Volume Controls Replacement: step 6, image 2 of 2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 273
