Create a Bootable USB Stick from an Older Version of macOS
  1. Create a Bootable USB Stick from an Older Version of macOS, Create a Bootable USB Stick from an Older Version of macOS: step 1, image 1 of 1
  2. Create a Bootable USB Stick from an Older Version of macOS: step 2, image 1 of 1
    • Open InstallMacOSX.dmg by double-clicking.
    • Double-click on InstallMacOSX.pkg
    • The installer runs
  3. Create a Bootable USB Stick from an Older Version of macOS: step 3, image 1 of 1
    • If you don't get the following error: "This version of OS X/macOS cannot be installed on this computer."
    • Wait for the end of the installation and follow the following tutorial : How to create a bootable USB drive
    • Otherwise, go to the next step.
  4. Create a Bootable USB Stick from an Older Version of macOS: step 4, image 1 of 1
    • Quit the installer and drag and drop the InstallMacOSX.pkg file on your Desktop
  5. Create a Bootable USB Stick from an Older Version of macOS: step 5, image 1 of 2 Create a Bootable USB Stick from an Older Version of macOS: step 5, image 2 of 2
    • Open Terminal and enter the following command: "cd Desktop"
    • Enter the following command: "pkgutil --expand ~/Desktop/InstallMacOSX.pkg FolderName" (You can change FolderName to any name you want)
    • A folder with the name you gave appears on your Desktop.
  6. Create a Bootable USB Stick from an Older Version of macOS: step 6, image 1 of 1
    • Open the folder appeared on the desktop.
    • Then, download the files here: https://github.com/ThonyF/iFixitTutoCrea...
    • Search for the macOS version corresponding to the installation you wish to perform and replace the distribution file in the folder that has been created.
  7. Create a Bootable USB Stick from an Older Version of macOS: step 7, image 1 of 2 Create a Bootable USB Stick from an Older Version of macOS: step 7, image 2 of 2
    • Go back to the terminal and type the following command: pkgutil --flatten FolderName New.pkg (FolderName = the name of the folder and New.pkg = the new .PKG file that will be created)
    • Press enter and wait for the file to be created
    • Launch the new .PKG file
    • Congratulations you can launch the installer.
    • To continue creating the USB Stick follow the following tutorial : How to create a bootable USB drive
You're done BRAVO !!
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Anthony Fassler
6,477 Reputation
4 Guides authored
3 Comments
Bonjours après l'étape 5 le terminal me renvois un "Could not open package for expansion: /Desktop/InstallMacOSX.pkg"
pourriez-vous m'aider s'il vous plait
Josheph - Reply
Bonjour,
Avez-vous bien le fichier ".pkg” sur le Bureau (Desktop en anglais) ?
Si oui, êtes-vous bien sûr le bureau dans le terminal ? ("cd Desktop” normalement il affiche "desktop” à gauche de ou vous écrivez.)
Pour être sûr, vous pouvez taper la commande "ls -al", ça affiche une liste et vous pouvez voir s'il y a bien le fichier dans cette liste. S'il n'y est pas, vous n'êtes pas au bon endroit.
Anthony Fassler -
Sorry! I've tried with Sierra an always get a Javascript Error... Good try though
Magne Olsen - Reply
Past 24 Hours: 29
Past 7 Days: 246
Past 30 Days: 932
All Time: 10,803
