Crown Range Hood AFG-AC/SS Light Bulb Replacement
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: step 1, image 1 of 1
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 2, image 1 of 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 2, image 2 of 2
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 3, image 1 of 1
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 4, image 1 of 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 4, image 2 of 2
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 5, image 1 of 1
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 6, image 1 of 1
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 7, image 1 of 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 7, image 2 of 2
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 8, image 1 of 1
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: step 9, image 1 of 1
    • Turn the light on to make sure your repair was successful!
Finish Line
Ken Cantago
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 31
All Time: 406
