DR.J Professional HI-04 Fan Replacement
  1. DR.J Professional HI-04 Fan Replacement, Fan: step 1, image 1 of 3 DR.J Professional HI-04 Fan Replacement, Fan: step 1, image 2 of 3 DR.J Professional HI-04 Fan Replacement, Fan: step 1, image 3 of 3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Fan Replacement: step 2, image 1 of 3 DR.J Professional HI-04 Fan Replacement: step 2, image 2 of 3 DR.J Professional HI-04 Fan Replacement: step 2, image 3 of 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Fan Replacement: step 3, image 1 of 2 DR.J Professional HI-04 Fan Replacement: step 3, image 2 of 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Fan Replacement: step 4, image 1 of 2 DR.J Professional HI-04 Fan Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Fan Replacement: step 5, image 1 of 2 DR.J Professional HI-04 Fan Replacement: step 5, image 2 of 2
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the power cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Fan Replacement: step 6, image 1 of 2 DR.J Professional HI-04 Fan Replacement: step 6, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Fan Replacement: step 7, image 1 of 2 DR.J Professional HI-04 Fan Replacement: step 7, image 2 of 2
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Fan Replacement: step 8, image 1 of 3 DR.J Professional HI-04 Fan Replacement: step 8, image 2 of 3 DR.J Professional HI-04 Fan Replacement: step 8, image 3 of 3
    • Gently remove the fan from the project.
Baron Dutra
825 Reputation
4 Guides authored
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 17
All Time: 111
