Daewoo DWC LDC1412S Water pump replacement Replacement
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: step 1, image 1 of 1
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: step 2, image 1 of 2 Daewoo DWC LDC1412S Water pump replacement Replacement: step 2, image 2 of 2
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: step 3, image 1 of 1
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: step 4, image 1 of 2 Daewoo DWC LDC1412S Water pump replacement Replacement: step 4, image 2 of 2
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: step 5, image 1 of 1
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: step 6, image 1 of 1
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: step 7, image 1 of 1
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
2 other people completed this guide.
hellotheworld
191 Reputation
1 Guide authored
One Comment
Thanks, this saved me heaps of money!!!
Brendan Innes - Reply
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 79
All Time: 3,666
