Datawind Ubislate 7ci Rear Facing Camera Replacement
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: step 1, image 1 of 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: step 2, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: step 2, image 2 of 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: step 3, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: step 3, image 2 of 2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: step 4, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: step 4, image 2 of 2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: step 5, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: step 5, image 2 of 2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: step 6, image 1 of 1
    • Press the back cover of the tablet on firmly until it clicks
2 other people completed this guide.
Mekides
40 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 293
