Dell Inspiron 15-7569 Battery Replacement
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: step 1, image 1 of 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: step 1, image 2 of 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: step 2, image 1 of 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: step 2, image 2 of 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: step 2, image 3 of 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
5 other people completed this guide.
Matthew Clements
546 Reputation
5 Guides authored
USF Tampa, Team S5-G4, Walkup Fall 2017 Member of USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Members
6 Guides authored
One Comment
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 6,217
