Dell Chromebook 11 CB1C13 Bottom Cover Replacement
  1. Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 1 of 3 Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 2 of 3 Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 3 of 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
Bryan Allen
272 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 866
