Dell Chromebook 3100 non-touch Battery Replacement
  1. Dell Chromebook 3100 non-touch Battery Replacement, Remove Bottom Cover: step 1, image 1 of 2 Dell Chromebook 3100 non-touch Battery Replacement, Remove Bottom Cover: step 1, image 2 of 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
  2. Dell Chromebook 3100 non-touch Battery Replacement, #1 - Remove Battery Screws: step 2, image 1 of 1
    • Remove the 3 battery screws with a Phillips #0 screwdriver.
    • Temporarily disconnect the bottom left corner battery sticker. NOTE* You will need to reconnect this sticker when installing the new battery.
    • Lift the battery out from the palmrest. NOTE* You may feel some resistants while trying to remove the battery. There is a double-sided sticky tape pad located underneath the battery in the top left corner. (See video)
    • Disconnect the motherboard battery cable from the top of the battery.
Jon
3,921 Reputation
22 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 22
All Time: 1,014
