Dell Chromebook 3100 non-touch Bottom Cover Replacement
  1. Dell Chromebook 3100 non-touch Bottom Cover Replacement, Remove Bottom Cover: step 1, image 1 of 2 Dell Chromebook 3100 non-touch Bottom Cover Replacement, Remove Bottom Cover: step 1, image 2 of 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
Jon
3,921 Reputation
22 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 18
All Time: 356
