Dell Inspiron 13 7378 Battery Replacement
  1. Dell Inspiron 13 7378 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 13 7378 Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 13 7378 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 13 7378 Battery Replacement: step 3, image 3 of 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the four screws from the battery using a Phillips #00 screwdriver.
  5. Dell Inspiron 13 7378 Battery Replacement: step 5, image 1 of 2 Dell Inspiron 13 7378 Battery Replacement: step 5, image 2 of 2
    • Disconnect the battery's black connector from the motherboard.
  6. Dell Inspiron 13 7378 Battery Replacement: step 6, image 1 of 2 Dell Inspiron 13 7378 Battery Replacement: step 6, image 2 of 2
    • Remove the battery from the laptop.
Replace the back cover to complete the process.
6 other people completed this guide.
Michelle Reyes
282 Reputation
1 Guide authored
Gateway, Team 1-3, Saknee Spring 2022 Member of Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 57
Past 30 Days: 266
All Time: 4,446
