Dell Inspiron 13-5368 Battery Replacement
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 13-5368 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 13-5368 Battery Replacement: step 2, image 2 of 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: step 3, image 1 of 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: step 4, image 1 of 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: step 5, image 1 of 2 Dell Inspiron 13-5368 Battery Replacement: step 5, image 2 of 2
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 other people completed this guide.
Matt Sugrim
1,042 Reputation
6 Guides authored
USF Tampa, Team S14-G6, Boczar Fall 2017 Member of USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Members
13 Guides authored
3 Comments
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Reply
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Reply
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 192
All Time: 24,541
