Dell Inspiron 13-5378 Display Assembly Replacement
  1. Dell Inspiron 13-5378 Display Assembly Replacement, Peeling the Tape: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Latches: step 2, image 1 of 1
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Display: step 3, image 1 of 1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Computer: step 4, image 1 of 1
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
    • Place the computer face down on a flat surface.
  5. Dell Inspiron 13-5378 Display Assembly Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  6. Dell Inspiron 13-5378 Display Assembly Replacement, Lifting the Display Assembly: step 6, image 1 of 1
    • Lift the display assembly off the palm-rest assembly.
  7. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
    • Place the NEW display assembly face down on the palm-rest assembly.
  8. Dell Inspiron 13-5378 Display Assembly Replacement, Align the Screw Holes: step 8, image 1 of 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
    • Close the display and turn the computer over.
  9. Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: step 10, image 1 of 2 Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: step 10, image 2 of 2
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  10. Dell Inspiron 13-5378 Display Assembly Replacement, Adhering the Pieces: step 11, image 1 of 1
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Terrence15
79,231 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 3,284
