Dell Inspiron 15 7579 Touchpad Replacement
  1. Dell Inspiron 15 7579 Touchpad Replacement, Touchpad: step 1, image 1 of 2 Dell Inspiron 15 7579 Touchpad Replacement, Touchpad: step 1, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the ten 8 mm securing the bottom panel.
    • Lift the bottom panel up and off of the chassis.
  2. Dell Inspiron 15 7579 Touchpad Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 Touchpad Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four 3.7 mm screws securing the battery.
    • Lift the battery up and out.
  3. Dell Inspiron 15 7579 Touchpad Replacement: step 3, image 1 of 3 Dell Inspiron 15 7579 Touchpad Replacement: step 3, image 2 of 3 Dell Inspiron 15 7579 Touchpad Replacement: step 3, image 3 of 3
    • Use the tip of a spudger to flip up the locking bars on the five ZIF connectors, then pull the ribbon cables directly out of their ports.
    • Use a Phillips #0 screwdriver to remove the four 2.2 mm screws along the top of the touchpad.
    • One 2.2 mm screw is hidden under the cables at the top right corner of the touchpad.
    • Lift the trackpad up and out.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 23
All Time: 310
