Dell Inspiron 17-5749 Keyboard Replacement
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 17-5749 Keyboard Replacement: step 2, image 2 of 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: step 4, image 1 of 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Christopher Tran
1,161 Reputation
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 426
