Dell Inspiron 7573 2-in-1 Battery Replacement
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: step 2, image 1 of 3 Dell Inspiron 7573 2-in-1 Battery Replacement: step 2, image 2 of 3 Dell Inspiron 7573 2-in-1 Battery Replacement: step 2, image 3 of 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: step 3, image 1 of 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: step 4, image 1 of 3 Dell Inspiron 7573 2-in-1 Battery Replacement: step 4, image 2 of 3 Dell Inspiron 7573 2-in-1 Battery Replacement: step 4, image 3 of 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Kylie Freese
405 Reputation
3 Guides authored
Casper College, Team 1-2, Lareau Fall 2021 Member of Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 48
All Time: 2,292
