Dell Inspiron N5030 Display Assembly Replacement
  1. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron N5030 Display Assembly Replacement, Open the Display: step 2, image 1 of 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Cable: step 3, image 1 of 1
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Display Cable: step 4, image 1 of 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron N5030 Display Assembly Replacement, Remove the Display Assembly: step 6, image 1 of 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron N5030 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron N5030 Display Assembly Replacement, Routing the Display Cable: step 8, image 1 of 1
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron N5030 Display Assembly Replacement, Routing the Antenna Cable: step 9, image 1 of 1
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron N5030 Display Assembly Replacement, Replace the Screws: step 10, image 1 of 1
    • Turn the computer over and replace the two screws at the base of the computer.
Finish Line
Terrence15
79,131 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,986 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 14
All Time: 386
