Dell Precision T7600 Thermal Paste Replacement for Overheating CPU
  1. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU, Thermal Paste: step 1, image 1 of 1
    • Turn off the computer and unplug the power cord.
  2. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 2, image 1 of 1
    • Press and hold the power button for 30 seconds.
  3. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 3, image 1 of 2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 3, image 2 of 2
    • Open the case using the handle on the side.
    • Locate the CPUs.
    • The two black boxes are radiators, the CPUs are under these two black boxes.
  4. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 4, image 1 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 4, image 2 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 4, image 3 of 3
    • Remove the four 18mm screws from each of the black radiators with a Phillips #0 screwdriver. (8 screws total)
  5. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 5, image 1 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 5, image 2 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 5, image 3 of 3
    • You need take all eight 18mm TONG DIN912 screws. (Each radiator has four.)
    • Remove the radiator vertically.
  6. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 6, image 1 of 2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 6, image 2 of 2
  7. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 7, image 1 of 2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 7, image 2 of 2
    • Squeeze 1 ML of thermal paste onto the clean CPU.
    • Don't worry about spreading the thermal paste around, as the pressure from the radiator should spread the paste evenly. You can check out this nifty Thermal Paste Application Guide if you need any help.
  8. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 8, image 1 of 2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 8, image 2 of 2
    • Replace the radiator tower, applying even pressure as you make contact with the CPU.
    • Tighten the screws slowly in a cross pattern, making sure that one side doesn't have more pressure than the other.
  9. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 9, image 1 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 9, image 2 of 3 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 9, image 3 of 3
    • Make sure the memory sticks are firmly affixed into the slots and the graphics card is connected.
    • The green check shows a good RAM connection and the X shows a bad one.
    • Close the case.
  10. Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 10, image 1 of 2 Dell Precision T7600 Thermal Paste Replacement for Overheating CPU: step 10, image 2 of 2
    • Plug in the power supply.
    • The power light should come one. This is the self-checking state, do not touch anything. Wait until the light goes off, indicating that the self-checking state is finished.
    • If the light does not go off (after 5 mins), you need to repeat steps 6 and 7.
HaoqingKang
213 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 856
