Dell XPS 12 9Q33 Battery Replacement
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    Dell XPS 12 9Q33 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Battery Replacement: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Battery Replacement: step 3, image 1 of 1
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
  4. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: step 4, image 1 of 1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
2 other people completed this guide.
Johnathan Hammond
44,980 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,102
