Dell XPS 13 9370 Battery Replacement
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: step 2, image 1 of 1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: step 3, image 1 of 2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: step 3, image 2 of 2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: step 4, image 1 of 1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: step 5, image 1 of 1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 other people completed this guide.
Max Kletskov
40,307 Reputation
16 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
8 Comments
Is the battery an original dell battery?
mnyousafva - Reply
Why doesn’t it say what tools are needed?
Noah Guirguis - Reply
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Reply
Instructions were perfect, thanks for the great guide!
surfdaworld - Reply
Boom, in a good way! I fixed it!
Chris Cox - Reply
Past 24 Hours: 13
Past 7 Days: 99
Past 30 Days: 481
All Time: 15,564
